parishpete
Jul 21, 2011Aspirant
ReadyNas duo HDD compatibility
I have an RND 2110 ReadyNas Duo. I returned one of a pair of Seagate 1Tb ST 31000528AS drives under RMA with SMART errors. The replacement drive arrived today but it's a Western Digital 1Tb WD10...
mdgm-ntgr
Jul 21, 2011NETGEAR Employee Retired
1. The list is up to date. Drives not on the list may/may not work. Tech support will deny support if you have issues.
2. Yes, however you must choose disks from the compatibility list.
