mdredze
May 23, 2012Aspirant
ReadyNAS Duo network problem, can't copy off data
I have a ReadyNAS duo with two 2TB drives using RAID 1. The device boots fine and I can connect to it using the web interface, TimeMachine or CIFS. However, after a few minutes of usage (actively conn...
Farnorthsurfer
May 26, 2012Aspirant
I recently had problems with my Duo which turned out to be the power supply unit. Although your symptoms are slightly different.
I used a free program for Windows called R-Linux which allowed me to recover most of my data. Although some was scrambled or not visible. Maybe that will help if all else fails.
