mdredze
May 23, 2012Aspirant
ReadyNAS Duo network problem, can't copy off data
I have a ReadyNAS duo with two 2TB drives using RAID 1. The device boots fine and I can connect to it using the web interface, TimeMachine or CIFS. However, after a few minutes of usage (actively conn...
mdredze
Jul 30, 2012Aspirant
I bought a new external harddrive and copied the data off through the USB port. The unit disconnects from the network but the copy continues. However, I was only getting USB 1 speeds so I had to let it run for a long time (weeks) and wasn't able to check on the progress. I haven't had a chance to go back and see if it finished copying.
