mdredze
May 23, 2012Aspirant
ReadyNAS Duo network problem, can't copy off data
I have a ReadyNAS duo with two 2TB drives using RAID 1. The device boots fine and I can connect to it using the web interface, TimeMachine or CIFS. However, after a few minutes of usage (actively conn...
Jul 30, 2012Guru - Experienced User
Direct connection means connecting the ethernet cable directly between the PC and the NAS.
You need to set the PC to use a compatible IP address (making it static) http://www.readynas.com/kb/faq/boot/how ... _pc_or_mac
