swenas
Feb 06, 2012Aspirant
ReadyNAS DUO problems with WD
I have a ReadyNas DOU which I have problems with. The NAS have been working fine for several years. One day one disk failed and I decided to change both so I bought two WD Caviar Green 2 GB (WDC WD2...
swenas
I found this in the dmesg.log:
EXT3-fs error (device dm-0): htree_dirblock_to_tree: bad entry in directory #24018978: rec_len is smaller than minimal - offset=0, inode=0, rec_len=0, name_len=0
Not really sure if it is hardware or simply file system problem.
Any ideas?
Should I reset the NAS all over again? Guess I have not any other option...
Any ideas?
