swenas
Feb 06, 2012Aspirant
ReadyNAS DUO problems with WD
I have a ReadyNas DOU which I have problems with. The NAS have been working fine for several years. One day one disk failed and I decided to change both so I bought two WD Caviar Green 2 GB (WDC WD2...
swenas
Feb 08, 2012Aspirant
I have backup for my data so its not a problem.
The factory reset did not solve the problem.
After a large amount of data has been copied to it; a sata reset is perfromed again.
Volume scan finds no problems.
I am beginning to wonder if the actual readynas has some kind of HW-problem.
