PuyRobin
Feb 08, 2024Aspirant
ReadyNAS Duo RAID Level 0
Hi, I have a ReadyNAS Duo - I can't log into it anymore, but can still access the files and put new one on it. I was wondwering can I take the drives out and pop them in to a USB caddy and still ha...
Feb 08, 2024Guru - Experienced User
PuyRobin wrote:I have a ReadyNAS Duo - I can't log into it anymore ...
Actually you can. There's a long thread here that gives you options.
Posts 1+5 give you one option.
Another is to use FireFox. Set security.tls.version.min to 1 (browse to about:config and search for the setting).
- PuyRobinFeb 11, 2024Aspirant
Yes I know about the thread you posted - but it's not an answer to my question. So not really that helpful....
- SandsharkFeb 11, 2024Sensei
Then better describe how you are unable to log in and we can offer other possible solutions.
The drives in your NAS are Linux formatted using LVM. There are methods you can use to access the files on a Linux or Windows system, but they are best just used for data recovery, not replacement of the NAS. And since you already have access to your files so you can back them up, you don't need to do that.
