PuyRobin
Feb 08, 2024Aspirant
ReadyNAS Duo RAID Level 0
Hi, I have a ReadyNAS Duo - I can't log into it anymore, but can still access the files and put new one on it. I was wondwering can I take the drives out and pop them in to a USB caddy and still ha...
Feb 08, 2024Guru - Experienced User
PuyRobin wrote:I have a ReadyNAS Duo - I can't log into it anymore ...
Actually you can. There's a long thread here that gives you options.
Posts 1+5 give you one option.
Another is to use FireFox. Set security.tls.version.min to 1 (browse to about:config and search for the setting).
PuyRobin
Feb 11, 2024Aspirant
Yes I know about the thread you posted - but it's not an answer to my question. So not really that helpful....
