PuyRobin
Feb 08, 2024Aspirant
ReadyNAS Duo RAID Level 0
Hi, I have a ReadyNAS Duo - I can't log into it anymore, but can still access the files and put new one on it. I was wondwering can I take the drives out and pop them in to a USB caddy and still ha...
PuyRobin
Feb 12, 2024Aspirant
It seems impossible to get a straight answer to a question!
Can I pop the 2 drives into a usb caddy and still have access to the content/file?
- StephenBFeb 12, 2024Guru - Experienced User
Sandshark did address it - the simple answer is no. Technically it can be done if you are using Linux, but not with Windows or MacOS. Which is why I focussed on fixing your problem with logging in.
What you can do is copy the files to a new drive. Based on your questions, you have no backup for the files, so that is something you need to do anyway. RAID-0 has no redundancy at all, so if either disk fails you will lose all your data.
