Triplet3
May 24, 2025Aspirant
ReadyNAS DUO RND2000V2
I was asked by a friend if I could have a look at her RND2000v2. It was "not working" anymore. I started it at my desk, it began to check the disks and started up as far as I can see. I installe...
May 24, 2025Guru - Experienced User
Use this instead:
#vers=2
<VirtualHost _default_:80>
SSLEngine off
# Eliminate HTTPS rewrite
# RewriteEngine on
# RewriteRule ^/admin/(.*)$ http://%{SERVER_NAME}/admin/$1 [R,L]
# RewriteRule ^/admin$ http://%{SERVER_NAME}/admin
# End Eliminate HTTPS rewrite
</VirtualHost>
Then connect with http://nas-ip-address/admin
You can also use https with FireFox. Set security.tls.version.min to 1 (browse to about:config and search for the setting).
Triplet3
Jun 01, 2025Aspirant
I use Firefox with HTTPS, thanks. I had to change the workgroup in windows to be able to use the shares. It works fine now.
