Rhodsi01
Jan 11, 2020Follower
ReadyNAS DUO RND2120 no connecting to Windows 10
I have recently swapped laptops and now on Windows 10 and connot get access to my ReadyNAS DUO RND2120. I have done all the things suggested in the forum as follows: Updated RAIDar to 6.5.0 Updated...
Jan 12, 2020Guru - Experienced User
Rhodsi01 wrote:
Enabled SMB 1.0/CIFS Client
when I try to map a drive I keep getting "You can't connect to the file share because it's not secure" and then goes on to refer to SMB1 protocol.
Either the SMB 1 client actually isn't enabled, or you have some internet security software (not from Microsoft) that isn't allowing the connection.
So if you do have internet security software installed, try disabling it and see if that makes a difference.
