mickus
Oct 20, 2014Aspirant
ReadyNAS Duo RND2150 help please...
Hi,
Thanks in advance. Sorry if this has been asked before, I have spent an hour on the forum and cannot find a definitive answer.
Have received this message:
"Disk 2 did not pass SMART self-assessment test. Please replace this disk as soon as possible. Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk."
Currently have installed 2 x Seagate 500gb drives; 1 x ST3500418AS and 1 x ST3500320AS.
I would like to upgrade to 1TB enterprise class but would like a recommendation as the 'ReadyNAS Hardware Compatability List' does not list RND2150.
Also, can I hot swap Disk 2 with the new 1TB drive, then once redundant hot swap Disk 1 with the new 1TB drive?
Cheers...
...Mickus
Cheers...
...Mickus
- mdgm-ntgrNETGEAR Employee RetiredThe RND2150 is the Duo (v1). The Duo (v1) shows under Legacy > ReadyNAS Duo on the compatibility list.
- mickusAspirantThanks mdgm!
Can I hot swap Disk 2 with the new 1TB drive, then once redundant hot swap Disk 1 with the new 1TB drive?
Cheers...
...Mickus - mdgm-ntgrNETGEAR Employee Retired
You mean once redundant hot swap Disk 1 with another new 1TB drive? If so, yes.
Do you have a backup? - mickusAspirantVery good.
Yes, backed up to the Synology DiskStation.
Thanks for your help mdgm!
...Mickus
