thehalms
Mar 30, 2015Aspirant
ReadyNAS Duo RND2150 no blue light
Good afternoon everyone, I would greatly appreciate if you would have some pointers for me. I have a ReadyNAS Duo RND2150 that stopped working Power went out and when I turned the device back on ...
RX
Mar 30, 2015Luminary
thehalms wrote: I have removed both disks and turned NAS back on. Same issue no blue light, fan is blowing and Disk1 and Disk2 green light toggles back and forth.
It seems that you have a faulty NAS chassis.
Is the NAS chassis detected on RAIDar even though there are no disks inside and the power LED is still off?
Is the ethernet LED lit up at the rear portion of your NAS when its directly connected to your PC?
Is your NAS a Duo v1 or v2? Check this link: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
Both the Duo v1 and v2 are already EOL (End-of-Life). You may want to contact Netgear Support to verify if your NAS chassis is still under hardware warranty: http://support.netgear.com/general/contact/#tab-call
