thehalms
Mar 30, 2015Aspirant
ReadyNAS Duo RND2150 no blue light
Good afternoon everyone, I would greatly appreciate if you would have some pointers for me. I have a ReadyNAS Duo RND2150 that stopped working Power went out and when I turned the device back on ...
Mar 31, 2015Guru - Experienced User
You wouldn't be adding the drives to the NAS. You'd be (optionally) upgrading the firmware on the unused NAS, and then installing all the drives from the old NAS in the original slots (with no other drives). Then power up.
It is reasonable safe, but there are volume checks done as part of the boot process that could fail, and result in file loss.
Linux Reader is purely passive, so you could try that method first.
