GaryMiller
Jul 05, 2011Aspirant
Readynas DUO: Second WD20EARS drive never works.
Hi, I am new to the forums and totally new to the Netgear ReadyNAS products so excuse me if I do something wrong. I looked at the FAQ but couldn't find a prompt answer to my question. I bought a...
GaryMiller
mdgm wrote: Boot Recovery should only be done if tech support or a Jedi recommends it.
If just one of your disks was having problems it could perhaps have been a bad disk or simply needed to be hooked up to a PC and have the partitions deleted off it.
Did not know that. The disk that was bad had no partitions on it as it was new. I hooked it up to a PC later to check if it was corrupt but it worked fine. I had no clue about the boot recovery but that probably messed up my ReadyNAS Duo. I hope the Netgear support can help. Otherwise I will return the product.
