GaryMiller
Jul 05, 2011Aspirant
Readynas DUO: Second WD20EARS drive never works.
Hi, I am new to the forums and totally new to the Netgear ReadyNAS products so excuse me if I do something wrong. I looked at the FAQ but couldn't find a prompt answer to my question. I bought a...
PapaBear1
Aug 02, 2011Apprentice
I would remove one disk and attach it to an SATA port on the motherboard of a PC and remove the partitions (disk management in Windows will do it nicely). Then start the Duo with the other disk in bay 1. If you have not upgraded to 4.1.7, do so and perform a factory default. Once it has booted and settled down, hot add the second drive in bay two.
Post back with the results.
