m-a-f
Jun 06, 2020Aspirant
ReadyNAS Duo Setup web page not loading after uppdate
A system update was performed on my ReadyNAS Duo, Radiator Sparc 4.1.16. The update was for Samba CVE-2017-7494. When the NAS was rebooted, the Setup webpage is no longer available! The framework is...
- Jun 07, 2020
Having done more searches in the forum, this is a know problem when updating the firmware!
The solution is in the following thread:
Re-installing PHP add-on, apache is working again, so it the access to the FrontView, phew!
Sandshark
Jun 06, 2020Sensei
m-a-f wrote:I'm able to use putty to login to the NAS. The following is reported in /var/log/frontview/error.log:
[warn] RSA server certificate CommonName (CN) `192.168.125.68' does NOT match server name!?
That's a warning to make sure you selected the right IP address. If you never got that before, I'm not sure why you'd get it after an update.
PHP Fatal error: Unable to start curl module in Unknown on line 0
Perhaps the PHP version you have is not compatible with the new OS version? Try an OS re-install and see if that fixes it. Be sure not to accidently do a Factory Default, which will wipe the data.
I've seen that basic symptom due to corrupted SMB configuration, whihc is also often fixed by an OS re-install. What apps are you running that might have modified them?
m-a-f
Jun 07, 2020Aspirant
Hi Sandshark,
Thanks for the reply. I've noticed that apache2 isn't starting and when I restart manually it's still not working correctly. I had radiator 4.1.14 installed, then as soon as I installed v4.1.16 yesterday, the access to Frontview has stopped along with the access to my webserver pages running on the NAS. I did see that v4.1.16 was an update to Samba, do you know whcih version of PHP it requires? I have PHP5 installed, don't know which subversion. I get the error about curl when trying to run php5. How can I install an up-to-date version of PHP?
- m-a-fJun 07, 2020Aspirant
Is it possible to uninstall the Raidiator v4.1.16 and go back to v4.1.14?
