newbuilder22
Jul 18, 2017Aspirant
ReadyNas Duo V1 HDD compatibility
With the constant change in HDD, I was looking at upgrading my HDD on my trusty Readynas Duo V1. Can someone tell me the max TB allowed and what they are running? Thanks
newbuilder22
Jul 19, 2017Aspirant
Hi
You have already answered it. What I mean is, what do people have in the readnas boxes that work well.
Jul 19, 2017Guru - Experienced User
I am using a WD20EFRX in mine (along with an older Seagate disk).
- st_1Aug 06, 2017Aspirant
As can be read in other threads, I recently upgraded to Seagate Ironwolf 2TB drivers.
Apart from the first drive being DoA, the new pair of Seagates works as could be desired.
They have an added advantage to the old (5 years or more) WD they replace:
The Ironwolfs run several several degrees Celcius cooler then the old WDs!
The Seagates are aroudn 36-37 degrees in my installation, slightly higher when doing lots of works, whereas the Western Digitals were alway in the 43-46 degrees range.
This means that the FAN in the Duo rarely have to crank up to higher revolutions, meaning the the installation is a lot quieter now! Horray!
- StephenBAug 07, 2017Guru - Experienced User
I'm glad the upgrade went well.
Generally I use WDC reds, but I do have some 1 TB Ironwolf models, and I've also found that they work well.
- PoldekOct 27, 2017Guide
Just 4 weeks ago uprgraded my Duo v1 with 2×Seagate Ironwolf 2TB. Everything went perfectly fine during the upgrade&expansion process. What is titbit that printserver function works much faster now than before the upgrage (it used to be really slow). BUT the temp. of the new disks is between 32 and 34 Celsius AND fan revs at approx. 1750 rpm. That's too noisy for me. Room temp. is around 21'C here. Need to replace fan now for quiet one.
- st_1Oct 27, 2017Aspirant
Glad to hear others having a smooth upgrade.
Never used mine as print server, but perhaps I should?
Nevertheless, you seem to have an enviable temperature on your disks.
Mine's currently at 35 and 36 degrees C, but they're not being used by anything ATM.
My fan's doing 1785, and I don't hear it.
When I had the WD in the box, I could easily hear the fan doing many more revs...
Thanks for posting the feedback!
st1
