craigygordon's avatar
craigygordon
ReadyNAS Duo V1 just sits there with the fan full pelt after power cuts
Hi all hoping you can help me.  I recently (6 months ago) dusted off this NAS and loaded it up with 2 disks.  It was working flawlessly up until last week where after a series of power cuts it now just keeps the fan on full speed when starting along with flashing all the lights 3 times every 10 seconds.  I have tried a factory reset with the PIN in the back for 25 seconds but this does nothing.  Is this device bricked?  I hope not as its was running well up until this point.
PS RAIDAR doesnt see it either.
  • Try powering down, and removing the disks (label by slot, so you know which is which).
    Then power up, and see if RAIDar finds it (reporting a no disks status).
    • craigygordon's avatar
      craigygordon
      Gave this a go and kept scanning for 30 mins plus and nothing 😞
      • StephenB's avatar
        Guru
        Did RAIDar find it before the power problem?
        Are you seeing a blinking light pattern on the LEDs?
        LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks.  The number of slow blinks will be the error code.
        Current error codes:
        1  - Vendor mismatch
        2  - No disks detected
        3  - Bad contents on root partition of disks
        4  - Flash error
        5  - Unsupported RAID configuration
        Also, is the ethernet LED lit on the back of the NAS?
ProSupport for Business
