IceniTribe
Sep 29, 2016Aspirant
ReadyNAS Duo V1, unable to access Frontview following upgrade to 4.1.15
I have just upgraded to 4.1.15 (having been promted from the NAS box) and now Frontview is not available. I have tried an OS intall from the boot menu but no change, I assume it just reinstalls 4...
- Sep 30, 2016
Do you have port forwarding setup? If so, someone might be trying to hack into your NAS.
You could do e.g.
# mkdir /tmp/tmp1235# cd /tmp/tmp1235
Copy the PHP add-on to that directory and extract the contents of it e.g. if it is called PHP.bin you could do
# dd if=PHP.bin skip=1 | tar -xv
# sh install.sh
Hopefully you are then able to access Frontview again. If not check what error you get. You may need to install other add-ons over the top of themselves or perhaps install a newer version of the PHP Sparc add-on if there is a newer version available.
Sep 29, 2016Guru - Experienced User
If ssh is enabled, then it does makes sense to try it. You'd use putty from a windows PC (or terminal on a mac). Username is "root", the password is the NAS admin password. If the OS reinstall was successful, the NAS admin password has been reset to netgear1
If you do get in, then please enter
df . -h
df . -i
and post the results here. One cause of this problem is a filling OS partition, and this information would help us diagnose if that is your issue (or not).
If you'd rather not mess around with this: Assuming you are the original purchaser, you can use my.netgear.com to get paid support. Ask about "per-incident" support.
IceniTribe
Thanks for your prompt response Stephen.
I am not at home at the moment but I wll do this later and post the results.
- PCJBSep 29, 2016Aspirant
Hi,
i have the same problem. I cannot get into Frontview after the 4.1.15 update.
My machine is a RND4000 with 4 1.5TB drives in a RAID array. I do have SSH and all shares appear to be working
This is what i get. (retyped as I dont know how to copy from SSH to here )
ReadyNAS:~# df . -h
FileSystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 620M 1.3G 32% /
ReadyNAS:~# df . -i
FileSystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 128000 16782 111218 14% /
I wondering if the firewall has been reset?
Any help appreciated
Paul ( in UK)
