IceniTribe
Sep 29, 2016Aspirant
ReadyNAS Duo V1, unable to access Frontview following upgrade to 4.1.15
I have just upgraded to 4.1.15 (having been promted from the NAS box) and now Frontview is not available. I have tried an OS intall from the boot menu but no change, I assume it just reinstalls 4...
- Sep 30, 2016
Do you have port forwarding setup? If so, someone might be trying to hack into your NAS.
You could do e.g.
# mkdir /tmp/tmp1235# cd /tmp/tmp1235
Copy the PHP add-on to that directory and extract the contents of it e.g. if it is called PHP.bin you could do
# dd if=PHP.bin skip=1 | tar -xv
# sh install.sh
Hopefully you are then able to access Frontview again. If not check what error you get. You may need to install other add-ons over the top of themselves or perhaps install a newer version of the PHP Sparc add-on if there is a newer version available.
IceniTribe
Thanks for your prompt response Stephen.
I am not at home at the moment but I wll do this later and post the results.
PCJB
Hi,
i have the same problem. I cannot get into Frontview after the 4.1.15 update.
My machine is a RND4000 with 4 1.5TB drives in a RAID array. I do have SSH and all shares appear to be working
This is what i get. (retyped as I dont know how to copy from SSH to here )
ReadyNAS:~# df . -h
FileSystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 620M 1.3G 32% /
ReadyNAS:~# df . -i
FileSystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 128000 16782 111218 14% /
I wondering if the firewall has been reset?
Any help appreciated
Paul ( in UK)
