IceniTribe
Sep 29, 2016Aspirant
ReadyNAS Duo V1, unable to access Frontview following upgrade to 4.1.15
I have just upgraded to 4.1.15 (having been promted from the NAS box) and now Frontview is not available. I have tried an OS intall from the boot menu but no change, I assume it just reinstalls 4...
- Sep 30, 2016
Do you have port forwarding setup? If so, someone might be trying to hack into your NAS.
You could do e.g.
# mkdir /tmp/tmp1235# cd /tmp/tmp1235
Copy the PHP add-on to that directory and extract the contents of it e.g. if it is called PHP.bin you could do
# dd if=PHP.bin skip=1 | tar -xv
# sh install.sh
Hopefully you are then able to access Frontview again. If not check what error you get. You may need to install other add-ons over the top of themselves or perhaps install a newer version of the PHP Sparc add-on if there is a newer version available.
PCJB
Oct 10, 2016Aspirant
Hi All,
I am pleased to report that reloading PHP worked fine and Frontview is now all is back up and running.
I did have a backup of the binaries and do have SSH enabled and use it regularily to check things, The instructions on how to
reinstall was very helpful.
I'll remember (and have made a note as well ) that when an update is performed some applications may need reinstalling.
Thanks again for great assistance
