Nauno
Jan 28, 2015Aspirant
Readynas duo v2 + 2x wd30efrx = pb
Hi, Configuration : Readynas Duo V2 , firmware 4.1.14 2x WD RED WD30EFRX disks (3To Western Digital) wich are in your compatibility list (http://kb.netgear.com/app/answers/detail/a_id/20641/~/ha...
RX
Jan 28, 2015Luminary
The ReadyNAS Duo that you got is a v1. Kindly read this: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
Also, 3TB disks are not support on ReadyNAS Duo v1 because it does not have GPT partitioning. Check this link: http://www.readynas.com/app/hcl_disk
You could only use 2TB disk/s on ReadyNAS Duo v1.
