horim80
Nov 30, 2011Guide
ReadyNAS Duo v2 & NV+ v2 File Protocol
Hi, I have read some post about Duo v2 and NV+2. It seems not support NFS, Rsync and even FTP.. Is this true? I have already checked the comparison chart and above protocol unckecked. In additio...
ColonelPanik
Jan 11, 2012Aspirant
yoh-dah wrote:
ColonelPanik wrote: Any idea if improved USB 3.0 support is in the works yet?
NTFS performance in 5.3.2 over USB improved quite a bit, as much as 5X. Check it out.
I started out with 5.3.2 and the kernel is not patched for the NEC controller issues that have been solved by the kernel team in Spring 2011. My thread here details the issues viewtopic.php?f=21&t=59515
Performance is great when you can get it to work. At this point I only use the DUO V2 for backups. Really disappointed with the poor support and buggy kernel on this. Still thinking about returning it. I bought this for its USB 3.0 support and for that purpose it's mostly a failure. I ended up modding another NAS I own and adding a USB 3.0 controller to it.
