horim80
Nov 30, 2011Guide
ReadyNAS Duo v2 & NV+ v2 File Protocol
Hi, I have read some post about Duo v2 and NV+2. It seems not support NFS, Rsync and even FTP.. Is this true? I have already checked the comparison chart and above protocol unckecked. In additio...
mdgm-ntgr
Jan 23, 2012NETGEAR Employee Retired
iesus wrote:
I have a few questions about my new NV+ V2 unit.
What version of RAIDiator are you running?
iesus wrote:
How are you doing woth those updates, i need FTP or NFS or SSH access (due to my permission problems below).
SSH access is already available via the EnableRootSSH add-on for ARM. See e.g. http://www.readynas.com/forum/viewtopic.php?p=338927#p338927
iesus wrote:
Also i cant install any addons bc. i get the message "invalid update image"
Sounds like you're using add-ons for the wrong platform.
iesus wrote:
Also have problem with disk space i added 4pcs of 3tb disks and have only 5,4tb total space(!)
after my calcualtions i should have about 8tb my best guess is that it has chosen to have raid 5+1spare but
i have not told it to =/.
Were these use disks? If so had they been formatted to use MBR not GPT?
Have you tried a factory default: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
