horim80
Nov 30, 2011Guide
ReadyNAS Duo v2 & NV+ v2 File Protocol
Hi, I have read some post about Duo v2 and NV+2. It seems not support NFS, Rsync and even FTP.. Is this true? I have already checked the comparison chart and above protocol unckecked. In additio...
iesus
Jan 23, 2012Aspirant
I am using the latest version of the firmware i belive it was 5,3,2 or something like that
i have tried to use the x86 (i get the error message "wrong architecture") and the sparc ("invalid update image") release but none seems to work.
!Thanks for the link!
Two of the disks were un-used, two were used some (about a month or two), they were ext3 formatted (mbr i guess)
in the "health" section it states the disks are ok and the size seems fine.
If i factory reset i loose my backups (again) =/, but i guess that's the final option
