horim80
Nov 30, 2011Guide
ReadyNAS Duo v2 & NV+ v2 File Protocol
Hi, I have read some post about Duo v2 and NV+2. It seems not support NFS, Rsync and even FTP.. Is this true? I have already checked the comparison chart and above protocol unckecked. In additio...
iesus
Jan 23, 2012Aspirant
Now i get the error message
SSH access failed to be enabled due to error 13.
____________________________________________________________________________________________________
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdc'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdd'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/md2 doesn't contain a valid partition table
Disk /dev/dm-0 doesn't contain a valid partition table
Disk /dev/sda: 3000.6 GB, 3000592982016 bytes
255 heads, 63 sectors/track, 364801 cylinders, total 5860533168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sda1 1 4294967295 2147483647+ ee GPT
Disk /dev/sdb: 3000.6 GB, 3000592982016 bytes
/dev/sdb1 1 4294967295 2147483647+ ee GPT
Disk /dev/sdc: 3000.6 GB, 3000592982016 bytes
256 heads, 63 sectors/track, 363376 cylinders, total 5860533168 sectors
/dev/sdc1 1 4294967295 2147483647+ ee GPT
Disk /dev/sdd: 3000.6 GB, 3000592982016 bytes
/dev/sdd1 1 4294967295 2147483647+ ee GPT
Disk /dev/md0: 4293 MB, 4293906432 bytes
2 heads, 4 sectors/track, 1048317 cylinders, total 8386536 sectors
Disk /dev/md1: 536 MB, 536858624 bytes
2 heads, 4 sectors/track, 131069 cylinders, total 1048552 sectors
Disk /dev/md2: 5991.5 GB, 5991515553792 bytes
2 heads, 4 sectors/track, 1462772352 cylinders, total 11702178816 sectors
I/O size (minimum/optimal): 65536 bytes / 131072 bytes
Disk /dev/dm-0: 5980.7 GB, 5980741959680 bytes
255 heads, 63 sectors/track, 727117 cylinders, total 11681136640 sectors
