horim80
Nov 30, 2011Guide
ReadyNAS Duo v2 & NV+ v2 File Protocol
Hi, I have read some post about Duo v2 and NV+2. It seems not support NFS, Rsync and even FTP.. Is this true? I have already checked the comparison chart and above protocol unckecked. In additio...
mdgm-ntgr
Jan 23, 2012NETGEAR Employee Retired
So they are all using GPT. I can only guess that you've had some problems due to using used disks. Would be best to backup your data and try a factory default and see if this fixes it.
