peatpete
Feb 24, 2019Aspirant
Readynas Duo v2 power adapter
Hello all.
My power adapter is now non-functioning.
I have been trying to find out what is the DC connector size of the OEM / compatible version please.
I found various power adapter th...
- Feb 24, 2019
I believe it is 2.1 x 5.5mm ( https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Replacement-Power-Supply-ReadyNAS-Duo-RND2000/m-p/1391279#M137196 )
Feb 24, 2019Guru - Experienced User
- peatpeteFeb 26, 2019Aspirant
Thank you
