eusebio84
Oct 22, 2024Aspirant
readynas duo v2 ssh connection
Hello
I have a readynas duo v2 and I have a problem with it because:
- when I log in via ssh to the console, I can't do anything there, i.e. basic Linux commands don't want to work, among others: sudo, mkdir, etc. And I also can't install via apt-get install, because it shows e.g. broken packages, unable to find repository, etc. Besides, when I take apt-get update, I still get errors like ignore etc.
I will add that I tried to change the content of sources.list by adding lines and it doesn't help. I have the latest firmware, 500 gb disk, ssh enable root installed.
How to avoid problems with this? I have no ideas what to do next to make everything work like Linux.
