Rumian
Feb 09, 2018Aspirant
ReadyNAS Duo V2, unable to access Frontview following install PHP module
Good morning, I have a big problem after installing the https://rnxtras.com/readynas-os5-arm PHP purchased, ours has stopped running. If Frontview does not work, I restarted the NAS to fact...
Feb 09, 2018Guru - Experienced User
Have you contacted WhoCares_ through his support forum at Mattermost? https://rnxtras.com/forums
Rumian
no, I wrote to info@readynasxtras.com but I have no answer I thought that someone from the current forum met with such a problem and tell you how to solve it
- StephenBFeb 09, 2018Guru - Experienced User
It's fine to ask here, but I suggest you click through to the mattersmost forum that WhoCares_ uses, and also post your issue there.
- WhoCares_Feb 09, 2018Mentor
Thanks StephenB! I actually saw the email and the posts here just a little later but I'm still at work and the problem most likely requires me to spend more time at it than my emplyoer is willing to let me have during work time ;)
