Cfou
Nov 14, 2013Aspirant
ReadyNas Duo V2 USB Sound Card
Hello
I would like to connect a USB sound card to my readynas duo v2. The aim is clearly to be able to play some sound from the NAS to my player with the mean of a jack link connection. I know that I can stream my media over the network but this is not an option for me.
So i bought a "3d sound card" , it is plug & play compatible. I put it on the NAS, for my bad THERE IS NO SOUND! Normal right ? I can tell that I am expecting something like this. With a ssh connection and with the command "lsusb" through a console, I can see that my usb sound card is listed right there. therefore I came to the conclusion that maybe sound devices are not supported by the readynas duo v2. One option I found is to recompile the kernel and add sound support as module. But this is deep and I do not have the skills needed to investigate further in this direction
Did anyone ever try to get usb sound card support from readynas duo v2 ? Your help is welcome ;-)
Thanks in advance
Thanks in advance
- ThrassAspirantI'm currently trying the same with a readynas 102,
but yes there is no other way then to compile the kernel modules yourself...
there are a couple of instructions out there how to do so, but in the end I ran into some additional trouble and am not done yet...
if you know someone else who has a readynas duo v2 he could compile the modules for you, other then that... no chance - CfouAspirantHello Thrass,
Thanks for your reply, Its is crazy that there is not so much information about that... Maybe in futur They should think about letting the sound module ON ;-) - CfouAspirantI manage to make the compilation and install the module, procedure taken from
. But now I am going through another problem.http://www.readynas.com/forum/viewtopic.php?f=35&t=61970
When I try to play, let's say a mp3 file I get this :
ALSA lib pcm_hw.c:1401:(_snd_pcm_hw_open) Invalid value for card
audio: No such file or directory
The commands I have done just after installing the sound module for the kernel were :mknod /dev/dsp c 14 3
mknod /dev/mixer c 14 0
modprobe snd-pcm-oss
modprobe snd-usb-audio
