mferlitsch
Aug 08, 2011Aspirant
ReadyNAS Duo with 1TB harddisk
Hi, I have got a ReadyNAS Duo with 1TB harddisk. Now I want to buy a second harddisk for RAID (redundancy) Is it possible to buy a 2TB harddisk (is cheaper than 1TB). Is it possible that this 2T...
PapaBear1
Aug 08, 2011Apprentice
That is exactly how it will be used. It will show the volume of the 2TB drive, but only allocate 1TB to the RAID volume. At some point in the future when you then upgrade the 1TB drive to a 2TB, your redundant volume will be expanded to 2TB (reboot required).
