crslnd
May 20, 2012Aspirant
ReadyNAS Duo Wont Connect Via Raidar
I have been looking through the posts and searching for a similar problem, but I am not finding a solution. I can see my Duo in Raidar, but Raidar cannot connect to it. It just times out when it att...
May 27, 2012Guru - Experienced User
Was the Duo configured to use a static address or DHCP?
