crslnd
May 20, 2012Aspirant
ReadyNAS Duo Wont Connect Via Raidar
I have been looking through the posts and searching for a similar problem, but I am not finding a solution. I can see my Duo in Raidar, but Raidar cannot connect to it. It just times out when it att...
May 27, 2012Guru - Experienced User
Ok. What IP address does RAIDar show?
Did the IP address range change with the new router?
What happens if you enter https:/nasip/admin manually in your browser address bar?
Two other things you can try: (a) a direct connect procedure, setting the PC with a manual address on the same subnet as the NAS (b) reinstalling the old router, and see if the connectivity is restored.
