crslnd
May 20, 2012Aspirant
ReadyNAS Duo Wont Connect Via Raidar
I have been looking through the posts and searching for a similar problem, but I am not finding a solution. I can see my Duo in Raidar, but Raidar cannot connect to it. It just times out when it att...
crslnd
May 29, 2012Aspirant
192.168.11.3
Yes, the IP address range changed (i think); older router died and have not been able to resurrect.
Would you elaborate on option (a) plug ethernet cable from NAS into computer then where do I change the range of my computer's IP address?
Thanks for your help!
