elaux402's avatar
elaux402
ReadyNAS failed power suppply
I have a failed power supply that I am trying to replace. The model on the old power supply is ST-220FUB-05E. When I look up this model number I keep finding power supplies that will fit physically but the DC output is off. 12v DC for instance only provides 7A and the replacements all provide 14A. The total power is usually off as well. The failed supply is 110W and new units are usually around 220W. Does anyone know where I can get a power supply that will work? I am afraid that the unit I keep seeing will provide too many amps and fry the unit.
      • bedlam1's avatar
        bedlam1
        Prodigy
        Oh it is a NVX, the wiring is modified for that model
        You should investigate this item LINK  a UK company but ship worldwide
  • As long as the available power is more than on the old one, there is no problem.  The device will only draw what it needs.  The supply is rated at the max it can provide.  If you are purchasing a standard Flex ATX and changing rewiring yourself, make sure there is only one 12V bus.  You cannot tie two together to provide the total power needed and the 12C busses typically shouldn't have no load (if you were to use only one).
ProSupport for Business
