PlanAndSimple
Jan 13, 2014Aspirant
Readynas integration
Hi, is the ReadyNAS Pro 2 compatible with UTM 150 for setting up quarantine?
xeltros
Jan 13, 2014Apprentice
Hi,
I found nothing for quarantine on the product description from Netgear. I'm not familiar with Netgear security products.
What do you call quarantine ? is it 802.1X authentication for ethernet, DMZ isolation, virus scan quarantine... ?
Do you plan on buying one of those products or is it just a setup matter ?
