jtaylor1's avatar
jtaylor1
ReadyNas NetGear failing and needing a reboot
We order countless readynas backup devices and ship them out to our customers. They fail so often that we have created a script to E-mail us when they fail. We then have to call our customer and reboot the device. This takes a lot of time out of our daily routine to do this. There has to be a logical reason why they're failing and need a reboot. I would like to solve this problem. Can anyone suggest where I might start my investigation?
If there is anymore information, I can provide please let me know.
Thanks.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    It doesn't look like you are using much space so I doubt it's full.
    I see you have been using shell commands.
    What protocol is used for your backups? Rsync? SMB? Something else?
  • Thank you for prompt response.
    We're using Rsync protocol.
    Any idea on why we're having to constantly call our client to have the reboot this device?
    Thanks.
    mdgm-ntgr
    I'm not sure. You may wish to open a tech support case. Let me know the case number.
    What version of Rsync are you running on the other device? Is it also a ReadyNAS or something else?
  • StephenB's avatar
    jtaylor wrote:
    Can you send me a link on how I open a support ticket.
    http://support.netgear.com You are entitled to free phone/chat support for 90 days after purchase, after that email is the free option.
  • Okay, I have tried to call the number, and automation leaves a lot to be desired. The automation kept lopping like a bad while loop and then eventually cut me off the phone. Tried to call back, and the phone to their business support is busy.
    Do you've a direct number I can reach someone at? We've at least 300-400 backupmates from Netgear with our customer I would except that the customer service would be a bit better.
    Thanks.
  • StephenB's avatar
    I don't have a direct number; hopefully one of the Netgear folks who post here will follow up with you.
ProSupport for Business
