DerekSW
Jul 03, 2020Follower
ReadyNAS not booting after firmware update to 6.10.3
After updating to 6.10.3 my device doesn`t boot.
I allready tried tot shutdown fot 10 minutes and the boot again.
I have network connection but can`t connect to the admin panel.
The device is detected bij Raidair, but keeps telling "system starting...."
He also detects the drives en indicates. ok.
What can i do to solve this?
Thanks for your help.
1 Reply
Do you have a backup of your data?
One option is to
- first try an OS reinstall
- then if that fails try a USB recovery
If you can boot into tech support mode, then you could also use paid netgear support (my.netgear.com).
