miogpsrocks's avatar
May 25, 2016
Readynas not recognizing true size of hard drive. 4TB X 4 = 10TB only available?
  So I have 4TB drives X 4 of them which should be around 16TB, subtract one for parity and you get 12TB.    If each 4TB drive is only 3721, and 1 drive is for parity, I should still have 11,163 T...
  • Retired_Member's avatar
    Retired_Member
    May 25, 2016
    Welcome to the world of overhead and rounding :D (I'll avoid listing BS as well)
    You can check NETGEAR's RAID calculator for a bit more information: http://rdconfigurator.netgear.com/raid/index.html
    1) 4HDDs in XRAID mode = RAID5, so as you said, one HDD is for parity
    2) A few GB of all HDDs are used for volume & swap
    3) HDD manufacturers made up something called TB & TiB. Instead of counting by multiples of 1024, they count in multiples of 1000. So a 4TB HDD is not 4 (T) * 1024 (G) * 1024 (M) * 1024 (K) * 1024 Bytes but 4 (T), 000 (G), 000 (M), 000 (K), 000 Bytes. They call the first one 4TiB. Computers have never counted in multiples of 1000, but that's what you can do with money & good lawyers to win lawsuits.
    4) When a volume is formatted, you need to count some overhead for the filesystem.
    5) After counting all this, you should get something like 10.9TiB. But the GUI rounds (or I should say truncates) it to 10TB.
    You can also notice that it's 10TB when it "should" be 10TiB. But really, TiB is just something made up by HDD manufacturers.
    https://en.wikipedia.org/wiki/Binary_prefix#Consumer_confusion
    So it does actually add up ;)
ProSupport for Business
