pimpyoda
Jul 15, 2020Aspirant
ReadyNAS NV+ - The remote device or resource will not accept the connection
I'm having trouble connecting to my ReadyNas NV+ via WiFi using Windows Explorer in Windows 10. Can access Frontview through Chrome, but for some reason I can no longer access the ReadyNas through Wi...
JohnCM_S
Jul 15, 2020NETGEAR Employee Retired
Hi pimpyoda,
Please verify if SMBv1 is enabled on your Windows 10 computer. You can enable SMBv1 by following these steps:
- Search in the start menu for ‘Turn Windows features on or off’ and open it
- Search for ‘SMB1.0/CIFS File Sharing Support’ in the list of optional features that appears, and select the checkbox next to it, then click OK.
If it is already enabled and you still have the same issue, can you check if you have the same issue when the computer is connected via Ethernet?
