pimpyoda
Jul 15, 2020Aspirant
ReadyNAS NV+ - The remote device or resource will not accept the connection
I'm having trouble connecting to my ReadyNas NV+ via WiFi using Windows Explorer in Windows 10. Can access Frontview through Chrome, but for some reason I can no longer access the ReadyNas through Wi...
JohnCM_S
Jul 21, 2020NETGEAR Employee Retired
Hi pimpyoda,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
- pimpyodaJul 21, 2020Aspirant
Hi,
Sorry for the delayed response. I had to order some cables for this.
SMB was already enabled except SMB 1.0/CIFS Server was not checked. I tried checking it and rebooting, but it still did not work. Automatic Removal and Client options were already checked.
I attached my laptop to the router via Ethernet and it still did not work. Got the same error.
I also tried to connect a USB cable to the USB port to see if I could access it that way, but I guess the USB port is just for backing up data from flash drives.
- StephenBJul 21, 2020Guru - Experienced User
and connecting a UPS.
But not for connecting to a PC.
There's no need to enable SMB 1 server on the PC.
Can you try this:
Open CMD on the PC and enter
net use * /delete /y net use t: \\192.168.0.2\C /user:admin nas-admin-password
using the real admin password of course. Be careful on the typing, particularly slashes and spaces.
The first command will terminate any open SMB sessions on the PC. The second will attempt to map the C volume to drive letter T.
Note this will not work if the NAS is using the default admin password (netgear1 on the original NV+, password on the NV+ v2).
After entering the first command, the response was:
There are no entries in the list.
After entering the second command, the response was:
System error 53 has occurred.
The network path was not found.
