pimpyoda
Jul 15, 2020Aspirant
ReadyNAS NV+ - The remote device or resource will not accept the connection
I'm having trouble connecting to my ReadyNas NV+ via WiFi using Windows Explorer in Windows 10. Can access Frontview through Chrome, but for some reason I can no longer access the ReadyNas through Wi...
pimpyoda
Jul 21, 2020Aspirant
net use * /delete /y net use t: \\192.168.0.2\C /user:admin nas-admin-password
After entering the first command, the response was:
There are no entries in the list.
After entering the second command, the response was:
System error 53 has occurred.
The network path was not found.
Jul 22, 2020Guru - Experienced User
That just means that there were no open sessions.
That can happen if the command is mistyped (and of course it will happen if the NAS IP address is wrong).
Are you seeing the normal C volume status in Frontview (when accessing the web ui in Chrome)?
Do you see the share list if you enter
net view \\192.168.0.2
- SandsharkJul 22, 2020Sensei
Also, make sure you are not running any security software that also blocks SMB1.
- pimpyodaJul 22, 2020Aspirant
Sandshark wrote:Also, make sure you are not running any security software that also blocks SMB1.
I'm using Webroot and Windows Defender Firewall that comes with Windows 10. Could those be causing the issue and is there a way to check?
- StephenBJul 22, 2020Guru - Experienced User
Just disable them.
Maybe also check that your NAS is still using IP address 192.168.0.2.
When I go to Status - Health from Frontview, everything is showing up as OK
With the net view command in CMD prompt, I get the following error:
