Designer2u
Aug 26, 2024Initiate
ReadyNAS NV+ 314 (RND4410) Rename
Hello, Currently: ReadyNAS NV+ 314 (RND4410), Windows 11 Pro, Dell Precision 3640 Tower, Hardwired Network. A firmware upgrade initiated an alert email stating; "The host name contains illegal c...
- Aug 26, 2024
Designer2u wrote:
The host name was changed to contain a hyphen ( - ), instead of an underscore ( _ ). Now all files and directories are "read only", and of course, I am unable to change the name back to the original. Any attempts to "append" permissions result with an error message that refers to the original host name.
Go into system->settings->https. Set the SSL Key Host to DEF-DRAWINGS.local and then press Apply.
Designer2u wrote:Currently: ReadyNAS NV+ 314 (RND4410)
You have an RN314. You do NOT have an NV+ (RND4410). If people think you do have that older model, they will give you wrong advice.
Aug 26, 2024Guru - Experienced User
- Designer2uAug 27, 2024InitiateStephenB
Much appreciation to you - that was the solution. Thank you for your kind and informative response. 👍
