CarlRossi
Feb 02, 2016Aspirant
ReadyNAS NV+ access #26406628
I have used this device for five years. The power supply died. I replaced it. Installed the drives are in the same locations. All files and access were back, AFP, CIFS, https (Frontview). Ther...
- Feb 03, 2016
No. This is not an issue with the firmware on the flash and if it was you should use USB Boot Recovery not TFTP.
There is every indication that this is a problem on the disks not on the flash.
Feb 02, 2016Guru - Experienced User
You could try per-incident support (though that could end up escalating to a data recovery contract).
It is also possible to mount the RAID array in an x86 linux system, and extract the data.
If you have the skills, you could also telnet into the box (after booting up in tech support mode). Though the data volume would need to be manually mounted, and it would be easy to do more damage.
- CarlRossiFeb 02, 2016Aspirant
See latest update to mgdm.
A corrupted something in the FW or OS copy??
Thanks so much for chiming in....
Carl
