bachrach44
Apr 04, 2022Follower
ReadyNAS NV+ and ssl
I'm using a ReadyNAS NV+. The web interface only supports TLS 1.0. Many browsers are beginning to pull support for TLS 1.0 as it's old and insecure. Chrome no longer supports it and no longer allows ...
Apr 04, 2022Guru - Experienced User
bachrach44 wrote:
If Netgear is going to support NV+ going forward we clearly need a new one.
Let's start here. Netgear stopped selling the NV+ v1 in 2011, and issued the final firmware for it in 2017. They've made it quite clear that they are no longer supporting it.
bachrach44 wrote:
Is it possible a plugin could do this?
Yes - if one could create the necessary sparc build environment, then one could create an add-on patch. WhoCares_ did this for 4.2.x and 5.3.x systems (which have easier build environments), but not for 4.1.x.
Not clear that anyone is willing to take this on.
