bachrach44
Apr 04, 2022Follower
ReadyNAS NV+ and ssl
I'm using a ReadyNAS NV+. The web interface only supports TLS 1.0. Many browsers are beginning to pull support for TLS 1.0 as it's old and insecure. Chrome no longer supports it and no longer allows ...
Sandshark
Jun 14, 2022Sensei
bachrach44 wrote:The possibility of turning off SSL and using HTTP is the epitome of "throwing the baby out with the bathwater".
I can't imagine a business still relying on such an outdated product. So, assuming it's in your home, do you really think somebody is going to try and sniff your home network just to break into your NAS?
If you do, how many computers access the NAS and is a separate wired-only network an option?
But you are right that access will likely become more and more difficult as technology progresses. So, it's probably time for you to start looking at options for a replacement.
