KrisW
Mar 23, 2015Aspirant
ReadyNAS NV+ ate my WD20EZRX (2TB Green)?
Hi guys, I bought two WD20EZRX - 00D8PB0 2TB "Green" drives to fit in my NV+ (v1, I guess - the PCB still says "Infrant"). The WD Green 20EARX model is on the compatibility list, and the EZRX sho...
KrisW
The problem is that both disks worked before they were put into the ReadyNAS. I cannot now mount them anywhere to be able to unlock them: my desktop PC refuses to boot up if either disk is on the SATA bus at power-up.
(I believe the Dell BIOS "password" prompt is spurious - the EZRX doesn't offer password protection as far as I can discover)
