KrisW
Mar 23, 2015Aspirant
ReadyNAS NV+ ate my WD20EZRX (2TB Green)?
Hi guys, I bought two WD20EZRX - 00D8PB0 2TB "Green" drives to fit in my NV+ (v1, I guess - the PCB still says "Infrant"). The WD Green 20EARX model is on the compatibility list, and the EZRX sho...
mdgm-ntgr
Mar 24, 2015NETGEAR Employee Retired
With the disks that aren't working if you are fine with wiping them can you try a factory reset using Flex-RAID?
1. Leave all locked drives in NV+
2. Perform factory default reset
3. From RAIDar, select flex RAID instead of XRAID
